Need help! How to create a filter based on groups with the same values
- Anonymous3 years ago
Hi nikitak224 ,
I created some data:
1. Enter data – Create a table.
2. Create measure.
Flag = var _select=SELECTCOLUMNS('Table',"1",[State]) VAR _SELECT1=SELECTEDVALUE('Table2'[Group]) return SWITCH( TRUE(), AND(_SELECT1="Group1" , "NJ" in _select || "CT" in _select || "TX" in _select || "AR" in _select ||"CA" IN _select ),1, _SELECT1="Group2" ,1, AND(_SELECT1= "Group3" , NOT("NJ") IN _select),1, AND(_SELECT1="Group4" , "NJ" IN _select),1,0 )3. Place [Flag]in Filters, set is=1, apply filter.
4. Result:
Select the corresponding Slicer to display the corresponding rules
Liu Yang
Hi nikitak224 ,
2. Create measure.
Flag =
return
SWITCH(
TRUE(),
4. Result:
Liu Yang
