Kareus's avatar
Kareus
2 years ago
Need Help: Filter Column Question
How can I DAX code this. The 1st column is a unique list of part # The 2nd column in a complete global list of item # I would like to make a 3rd column that shows (complete global list of item # f...
  • Daniel29195's avatar
    2 years ago
    Kareus
    if you are aiming at creating a new calculated table showing the gloabl list of items filtering out the list of parts :
    caluclated table =
    except ( all(tbl[item_col_name]) ,  all(tbl[parts_col_name]))
    let me know if this helps .
    If my answer helped sort things out for you, i would appreciate a thumbs up 👍 and mark it as the solution ✅
    It makes a difference and might help someone else too. Thanks for spreading the good vibes! 🤠
