Need Help: Filter Column Question
- 2 years ago
if you are aiming at creating a new calculated table showing the gloabl list of items filtering out the list of parts :
caluclated table =
except ( all(tbl[item_col_name]) , all(tbl[parts_col_name]))
let me know if this helps .
If my answer helped sort things out for you, i would appreciate a thumbs up 👍 and mark it as the solution ✅
It makes a difference and might help someone else too. Thanks for spreading the good vibes! 🤠
caluclated table =
- Kareus2 years ago
I can make that work. Thank you!
