Anonymous's avatar
6 years ago
Need help converting excel statement power query
Is it possible to create a custom column with a series of if statements that produce a concatenated string? I have done this in Excel but can't recreate it in power query for a custom column.  My excel text is as follows:
=IF([@[Customer Survey Status]] ="Completed", 1,(IF(Customer Survey Status="In Review",1,0))) & "," & IF([@[Partner Survey Status]]="Completed", 1,(IF([@[Partner Survey Status]]="In Review",1,0))) & "," & IF([@[Document Status]]="Completed",1,(IF([@[Document Status]]="In Review",1,0))) & "," & IF([@[Invoice Status]]="Completed",1,(IF([@[Invoice Status]]="In Review",1,0)))
I've tried the If statement and the text.contains methods but can't get either to work.
Result desired is something like 0,1, 0,1
I did post a 30 minutes ago but can't see it in the forums so reposting, sorry if this is a duplicate.
Thanks!
  • You can pretty much directly translate this into Power Query code.  There are no brackets for if ... then ... else  but the rest is nearly the same.
    Something like
    =Table.AddColumn(#"Previous Step", each
    (if [Customer Survey Status] ="Completed" or [Customer Survey Status]="In Review"
        then "1," else "0,") &
    (if [Partner Survey Status]="Completed" or [Partner Survey Status]="In Review"
    (if [Document Status]="Completed" or [Document Status]="In Review"
    (if [Invoice Status]="Completed" or [Invoice Status]="In Review"
        then "1" else "0")
    Or if you want to use List.Contains:
    let l = {"Completed","In Review"}
    (if List.Contains(l,[Customer Survey Status] then "1," else "0,") &
    (if List.Contains(l,[Partner Survey Status] then "1," else "0,") &
    (if List.Contains(l,[Document Status] then "1," else "0,") &
    (if List.Contains(l,[Invoice Status] then "1" else "0")
    Something like
        then "1" else "0")
      Thanks so much, this really helped!
