PowerBigginer's avatar
PowerBigginer
1 year ago
Need help calculating working hours difference between two dates
Hello Team,
I’m currently facing challenges in Power Query while trying to calculate the difference in days between two dates, considering only working days, working hours, and excluding holidays.
Although I have a DAX-based solution that works as expected in terms of logic, it has performance issues. When attempting the same in Power Query, I'm encountering errors, especially for tickets created outside of working hours.
I would appreciate your help in resolving this.
Please find below my DAX and Power Query scripts for reference.
Dax
Days_Difference Exclude weekends =
VAR SubmittedDateTime = 'tbl_Service Request'[SR_CREATED]
VAR ResolvedDateTime = COALESCE( 'tbl_Service Request'[SR_CLOSE_DATE], NOW())
-- Define working hours
VAR WorkingStartTime = TIME(8, 0, 0) -- 8:00 AM
VAR WorkingEndTime = TIME(17, 0, 0) -- 5:00 PM
VAR WorkingHoursPerDay = 9
VAR StartHour = 8
VAR EndHour = 17
-- Adjust start time (if after working hours, move to next day)
VAR AdjustedStartTime =
IF(
TIME(HOUR(SubmittedDateTime), MINUTE(SubmittedDateTime), SECOND(SubmittedDateTime)) > WorkingEndTime,
DATEVALUE(SubmittedDateTime) + 1 + WorkingStartTime,
MAX(SubmittedDateTime, DATEVALUE(SubmittedDateTime) + WorkingStartTime)
-- Adjust end time (if after working hours, move to end of working day)
VAR AdjustedEndTime =
IF(
TIME(HOUR(ResolvedDateTime), MINUTE(ResolvedDateTime), SECOND(ResolvedDateTime)) > WorkingEndTime,
DATEVALUE(ResolvedDateTime) + WorkingEndTime,
ResolvedDateTime
-- Define start and end dates and times for calculations
VAR StartDate = DATE(YEAR(AdjustedStartTime), MONTH(AdjustedStartTime), DAY(AdjustedStartTime))
VAR StartTime = TIME(HOUR(AdjustedStartTime), MINUTE(AdjustedStartTime), SECOND(AdjustedStartTime))
VAR EndDate = DATE(YEAR(AdjustedEndTime), MONTH(AdjustedEndTime), DAY(AdjustedEndTime))
VAR EndTime = TIME(HOUR(AdjustedEndTime), MINUTE(AdjustedEndTime), SECOND(AdjustedEndTime))
-- If the ticket is within the same working day, calculate the difference based on start and end times
VAR SameDayWorkingHours =
IF(
StartDate = EndDate &&
RELATED('DimDate'[IsWorkingDay]) = TRUE(),
MAX(0, DATEDIFF(AdjustedStartTime, AdjustedEndTime, SECOND)) / 3600,
0
-- Calculate the number of seconds for the start day and end day if it's not the same day
VAR StartDaySeconds =
IF(
COUNTROWS(
FILTER(
'DimDate',
'DimDate'[CalendarDate] = StartDate &&
'DimDate'[IsWorkingDay] = TRUE()
) > 0,
MAX(0, DATEDIFF(AdjustedStartTime, DATEVALUE(AdjustedStartTime) + WorkingEndTime, SECOND)),
0
VAR EndDaySeconds =
IF(
COUNTROWS(
FILTER(
'DimDate',
'DimDate'[CalendarDate] = EndDate &&
) > 0,
MAX(0, DATEDIFF(DATEVALUE(AdjustedEndTime) + WorkingStartTime, AdjustedEndTime, SECOND)),
0
-- Calculate the number of full working days between start and end (exclusive)
VAR FullWorkingDays =
COUNTROWS(
FILTER(
'DimDate',
'DimDate'[CalendarDate] > StartDate &&
'DimDate'[CalendarDate] < EndDate &&
-- Total working hours from full days
VAR FullDaysHours = FullWorkingDays * WorkingHoursPerDay
VAR TotalWorkingHours =
IF(SameDayWorkingHours > 0, SameDayWorkingHours, (StartDaySeconds + EndDaySeconds) / 3600 + FullDaysHours)
CEILING(TotalWorkingHours/WorkingHoursPerDay,1)
Power Query M Code
// Load data
Source = Sql.Database("RV2IVWPBI1P\RAYAMSSQLSERVER", "RayaOperationsData"),
SR = Source{[Schema="dbo", Item="Fact_Siebel_ServiceRequest"]}[Data],
// Remove unwanted columns
RemovedCols = Table.RemoveColumns(SR, {
"SR_TYPE", "SUB_AREA", "PRIORITY", "REQUESTOR_NAME_EN", "SEVERITY",
"SR_DUE_DATE", "TOTAL_TIME", "VEHICLE_MAKE", "VEHICLE_MODEL", "MODEL_YEAR",
"PENDING_PAYMENT_START", "PENDING_PAYMENT_END", "LAST_UPD", "dw_created", "dw_last_upd"
ChangedTypes = Table.TransformColumnTypes(RemovedCols, {
{"SR_CREATED", type datetime},
{"SR_CLOSE_DATE", type datetime}
// Define working hours
WorkingStart = #time(8, 0, 0),
WorkingEnd = #time(17, 0, 0),
// 🟨 Holiday List
HolidayList = {
#date(2025, 3, 30), #date(2025, 3, 31), #date(2025, 4, 1), #date(2025, 4, 2),
#date(2025, 6, 5), #date(2025, 6, 8), #date(2025, 6, 9), #date(2025, 6, 10)
// ✅ Adjust Created Date
AdjustedStart = Table.AddColumn(ChangedTypes, "AdjustedStart", each
dt = [SR_CREATED],
defaultTime = #time(8, 0, 0),
safeDT = if dt = null then DateTime.LocalNow() else dt,
t = Time.From(safeDT),
d = Date.From(safeDT),
dow = Date.DayOfWeek(d, Day.Sunday),
nextWorkDate =
List.First(
List.Select(
List.Dates(d + 1, 7, #duration(1,0,0,0)),
each Date.DayOfWeek(_, Day.Sunday) <= 4 and not List.Contains(HolidayList, _)
adjusted =
if dow > 4 or List.Contains(HolidayList, d) then
DateTime.From(nextWorkDate + defaultTime)
else if t < defaultTime then
DateTime.From(d + defaultTime)
else if t >= WorkingEnd then
else safeDT
adjusted
, type datetime),
// ✅ Adjust Closed Date
AdjustedEnd = Table.AddColumn(AdjustedStart, "AdjustedEnd", each
dt = if [SR_CLOSE_DATE] = null then DateTime.LocalNow() else [SR_CLOSE_DATE],
t = Time.From(dt),
d = Date.From(dt),
adjusted =
if t < WorkingStart then
DateTime.From(d + WorkingStart)
else if t > WorkingEnd then
DateTime.From(d + WorkingEnd)
else dt
adjusted
, type datetime),
// Date Range
AddDateRange = Table.AddColumn(AdjustedEnd, "DateRange", each
s = Date.From([AdjustedStart]),
e = Date.From([AdjustedEnd])
List.Dates(s, Duration.Days(e - s) + 1, #duration(1, 0, 0, 0))
, type list),
// Working Days (Sunday–Thursday, excluding holidays)
WorkingDates = Table.AddColumn(AddDateRange, "WorkingDates", each
List.Select([DateRange], each Date.DayOfWeek(_, Day.Sunday) <= 4 and not List.Contains(HolidayList, _))
, type list),
// Calculate Working Hours
WorkingHours = Table.AddColumn(WorkingDates, "WorkingHours", each
startDT = [AdjustedStart],
endDT = [AdjustedEnd],
startDate = Date.From(startDT),
endDate = Date.From(endDT),
dates = [WorkingDates],
hours = List.Sum(
List.Transform(dates, each
currentDate = _,
startTime = if currentDate = startDate then Time.From(startDT) else WorkingStart,
endTime = if currentDate = endDate then Time.From(endDT) else WorkingEnd,
validStart = if startTime < WorkingStart then WorkingStart else startTime,
validEnd = if endTime > WorkingEnd then WorkingEnd else endTime,
duration = Duration.TotalHours(validEnd - validStart)
if validEnd > validStart then duration else 0
if startDT = null or endDT = null then null else Number.Round(hours, 2)
, type number),
// Calculate SLA Working Days (9 hours per day rule)
SLA_WorkingDays = Table.AddColumn(WorkingHours, "SLA_WorkingDays", each
wh = [WorkingHours]
if wh = null then null
else if wh < 9 then 0
else Number.RoundUp(wh / 9)
, type number),
Cleanup = Table.RemoveColumns(SLA_WorkingDays, {"DateRange", "WorkingDates"})
Cleanup
  • Hi PowerBigginer ,
    Your Power Query code is likely failing because the logic to adjust the start and end times doesn't correctly handle all scenarios, particularly when a ticket is created or closed on a non-working day (like a weekend or holiday) or outside the 8 AM to 5 PM window. The errors arise when the code cannot find a valid working day or time to "snap" to.
    The most effective solution is to use a robust, self-contained custom function that can accurately calculate the duration. This approach fixes the errors and is much cleaner than adding multiple intermediate columns to your table. You can create a new blank query, name it fxCalculateWorkingHours, and paste the following M code into the Advanced Editor. This function encapsulates all the complex logic for adjusting dates and calculating hours.
        StartDateTime as nullable datetime,
        EndDateTime as nullable datetime,
        optional Holidays as list,
        optional StartHour as number,
        optional EndHour as number
    ) as nullable number =>
        // 1. Define Parameters & Handle Nulls
        HolidaysList = if Holidays = null then {} else Holidays,
        WorkingStart = #time(if StartHour = null then 8 else StartHour, 0, 0),
        WorkingEnd = #time(if EndHour = null then 17 else EndHour, 0, 0),
        WorkingHoursPerDay = Duration.TotalHours(WorkingEnd - WorkingStart),
        ActualStart = StartDateTime,
        ActualEnd = if EndDateTime = null then DateTime.LocalNow() else EndDateTime,
        // Exit if no start date or if end is before start
        BailOut = ActualStart = null or ActualEnd < ActualStart,
        // 2. Helper function to find the next valid start time
        fnAdjustStart = (dt as datetime) =>
            datePart = Date.From(dt),
            timePart = Time.From(dt),
            // Recursive check for the next working day
            FindNextWorkDate = (checkDate as date) =>
                if Date.DayOfWeek(checkDate, Day.Sunday) > 4 or List.Contains(HolidaysList, checkDate) then
                    @FindNextWorkDate(Date.AddDays(checkDate, 1))
                else
                    checkDate,
            // Determine the adjusted start
            AdjustedStart =
                    NextWorkDay = FindNextWorkDate(datePart)
                    if datePart < NextWorkDay then NextWorkDay + WorkingStart // Start was on a non-working day
                    else if timePart >= WorkingEnd then FindNextWorkDate(Date.AddDays(datePart, 1)) + WorkingStart // Start was after hours
                    else if timePart < WorkingStart then datePart + WorkingStart // Start was before hours
                    else dt // Start was during work hours
            AdjustedStart,
        // 3. Helper function to find the previous valid end time
        fnAdjustEnd = (dt as datetime) =>
            // Recursive check for the previous working day
            FindPrevWorkDate = (checkDate as date) =>
                    @FindPrevWorkDate(Date.AddDays(checkDate, -1))
                else
                    checkDate,
            // Determine the adjusted end
            AdjustedEnd =
                    PrevWorkDay = FindPrevWorkDate(datePart)
                    if datePart > PrevWorkDay then PrevWorkDay + WorkingEnd // End was on a non-working day
                    else if timePart < WorkingStart then FindPrevWorkDate(Date.AddDays(datePart, -1)) + WorkingEnd // End was before hours
                    else if timePart > WorkingEnd then datePart + WorkingEnd // End was after hours
                    else dt // End was during work hours
            AdjustedEnd,
        // 4. Main Calculation
        TotalHours = if BailOut then 0 else
            // Adjust the start and end times using the helper functions
            AdjStart = fnAdjustStart(ActualStart),
            AdjEnd = fnAdjustEnd(ActualEnd),
            // If adjusted end is before adjusted start, duration is zero
            hours = if AdjEnd <= AdjStart then 0 else
                StartDate = Date.From(AdjStart),
                EndDate = Date.From(AdjEnd),
                // Generate list of relevant dates
                DateList = List.Dates(StartDate, Duration.Days(EndDate - StartDate) + 1, #duration(1,0,0,0)),
                // Filter for working days only (Sunday-Thursday, excluding holidays)
                WorkingDaysList = List.Select(DateList, each Date.DayOfWeek(_, Day.Sunday) <= 4 and not List.Contains(HolidaysList, _)),
                // Calculate hours for each working day in the list
                HoursList = List.Transform(WorkingDaysList, each
                       currentDate = _,
                       dayStart = if currentDate = StartDate then Time.From(AdjStart) else WorkingStart,
                       dayEnd = if currentDate = EndDate then Time.From(AdjEnd) else WorkingEnd
                       Duration.TotalHours(dayEnd - dayStart)
                List.Sum(HoursList)
            hours
        TotalHours
    After creating the function, you can replace your existing table query with the much simpler script below. This code loads your data, defines your holidays, and then calls the fxCalculateWorkingHours function to add a column with the total working hours. A final step calculates the SLA_WorkingDays based on those hours, mirroring the logic from your DAX formula.
        // Load data
        // Change required column types
        ChangedTypes = Table.TransformColumnTypes(SR, {
        // Define your list of holidays
        HolidayList = {
        // Calculate Working Hours by invoking the custom function
        AddWorkingHours = Table.AddColumn(ChangedTypes, "WorkingHours", each
            fxCalculateWorkingHours(
                [SR_CREATED],
                [SR_CLOSE_DATE],
                HolidayList,
                8, // Working Start Hour
                17 // Working End Hour
            type number
        // Calculate SLA Days (This matches your DAX CEILING logic)
        AddSLADays = Table.AddColumn(AddWorkingHours, "SLA_WorkingDays", each
                wh = [WorkingHours]
                if wh = null or wh <= 0 then 0 else Number.RoundUp(wh / 9),
            type number
        // Final cleanup
        FinalTable = Table.SelectColumns(AddSLADays, {"SR_NUMBER", "SR_CREATED", "SR_CLOSE_DATE", "WorkingHours", "SLA_WorkingDays"})
        FinalTable
    This approach significantly improves your query. The function provides robust date adjustments, correctly finding the nearest valid working time even across long holiday weekends. It successfully handles all edge cases, such as tickets created before, after, or during non-working periods. By encapsulating the complex logic, your main query becomes much simpler and more readable. Finally, the SLA calculation is correct, using Number.RoundUp to properly match the CEILING logic from your working DAX formula.
    Best regards,
  • DataNinja777  Thanks for you reply
    Getting same result as before
    If you see screenshot ticket closed 5:37 which is non working hour. Result returning with error
  • I am creating day difference betweek created and closed the tickets
    My requirement is
    if ticket got created non working hours I should adjust the time to working hours
    ex: if ticket create morning 7 it should adjust same day 8 am (my working hours are 8AM-5PM)
    if any ticket created after 5PM should change to next day 8AM
    To calculate accurate result
    same if any ticket opend in weekends or holidays should refelct to next working day
    Below is my Mcode which is not working for the above cases and result returning with error
    // Load data
    // 🟨 Holiday List
    HolidayList = {
    dt = [SR_CREATED],
    workingEnd = #time(17, 0, 0),
    isWeekend = dow = 5 or dow = 6, // Friday = 5, Saturday = 6 (Sunday = 0)
    isHoliday = List.Contains(HolidayList, d),
    nextWorkingDate =
    List.First(
    List.Select(
    each
    let wd = Date.DayOfWeek(_, Day.Sunday)
    in (wd <> 5 and wd <> 6) and not List.Contains(HolidayList, _)
    adjusted =
    if isWeekend or isHoliday then
    DateTime.From(nextWorkingDate & defaultTime)
    DateTime.From(d & defaultTime)
    else if t >= workingEnd then
    else
    safeDT
    adjusted,
    type datetime
    t = Time.From(dt),
    d = Date.From(dt),
    adjusted =
    else dt
    adjusted
    , type datetime),
    // Date Range
    , type list),
    , type list),
    hours = List.Sum(
    currentDate = _,
    , type number),
    wh = [WorkingHours]
    , type number),
    Cleanup
