Need help calculating Null and No null values in column
- 7 years ago
Hi parry2k
Test with this data
First Create a calculated column
year/weeknum = YEAR(Table1[Date])&"-"&WEEKNUM(Table1[Date],2)
Then Create two measures
count not null =
CALCULATE(COUNT(Table1[Date]),FILTER(ALLSELECTED(Table1),Table1[year/weeknum]=MAX(Table1[year/weeknum])&&Table1[Test Number]<>BLANK())) count null =
CALCULATE(COUNT(Table1[Date]),FILTER(ALLSELECTED(Table1),Table1[year/weeknum]=MAX(Table1[year/weeknum])&&Table1[Test Number]=BLANK()))Add them to a line chart
MaggieCommunity Support Team _ Maggie Li
Thanks! That's a great example, and I think we're getting closer to where I want v-juanli-msft . As I mentioned earlier to parry2k, I'm looking to generate a "Line Chart" that will have the Week# in the Axis and the Value would be the number of Tests per Week compared to the null values per week. Please see my previous example for additional details. Thanks!
Hi parry2k
Test with this data
count not null =
Maggie
Thank you all for your help. Another solution I implemented was to create 2 line charts one that shows the total number of cells with value per week and another chart that show the total number of nulls per week.
