Need help calculating Null and No null values in column
- 7 years ago
Hi parry2k
Test with this data
First Create a calculated column
year/weeknum = YEAR(Table1[Date])&"-"&WEEKNUM(Table1[Date],2)
Then Create two measures
count not null =
CALCULATE(COUNT(Table1[Date]),FILTER(ALLSELECTED(Table1),Table1[year/weeknum]=MAX(Table1[year/weeknum])&&Table1[Test Number]<>BLANK())) count null =
CALCULATE(COUNT(Table1[Date]),FILTER(ALLSELECTED(Table1),Table1[year/weeknum]=MAX(Table1[year/weeknum])&&Table1[Test Number]=BLANK()))Add them to a line chart
MaggieCommunity Support Team _ Maggie Li
Hi Anonymous
Please clear me how the line chart should look like?
Here is my test:
Since average for null values would get null for all rows, so i count how many rows are null.
Could you show me some example data and describe more about your expected visual?
Maggie
Thanks! That's a great example, and I think we're getting closer to where I want v-juanli-msft . As I mentioned earlier to parry2k, I'm looking to generate a "Line Chart" that will have the Week# in the Axis and the Value would be the number of Tests per Week compared to the null values per week. Please see my previous example for additional details. Thanks!
- v-juanli-msft7 years ago
Hi parry2k
Test with this data
count not null =
If this post helps, then please consider Accept it as the solution to help the other members find it more quickly.- Anonymous7 years agoNot applicable
Thank you all for your help. Another solution I implemented was to create 2 line charts one that shows the total number of cells with value per week and another chart that show the total number of nulls per week.
