Multiple drill through paths between same two sources in Power BI
Hi All
I have two reports in Power BI which coming from two sources (excel sheets).
There is a hierarchy in the data which goes from Service --> Sub Service
I have currently a drill through set up at the subservice level, which is working correctly.
But now the client also wants a drill through at Service level also along with existing sub service level.
Is that possible, between the same two sources?
Or do we have to move the data for service into a third source? ( I am trying to avoid this scenario)
Rgds
Amit
Hi Anonymous ,
Hence I am getting a feeling that drill through between the same two sources at multiple levels is not possible unless you put the summary data in a third sheet? Is that correct? Pls confirm if I am incorrect and there is a way?
In your scenario, that's true.
- amitchandak
Assuming Service and Sub service is a common dimension it should happen.
Not sure of the exact issue. Can you please explain with an example.
Appreciate your Kudos.- AnonymousNot applicable
Hi Amitchandak
Thanks for your reply.
File 1: IT Financials has summary data in Excel format
with lots of columns
1. Portfolio
2. Cost Driver
3. Cost Driver Detail
4. Busines Area
5. Services
6. Sub Service
I have created a key, which joins all the above columns
The same columns exist in the detail Sheet called "Power BI Mockup".
A similar key consisting of the above columns exist in the detailed sheet.
Join has been created between the two key columns and drill through has been created at Sub Service Level currently.
Now the customer is saying that we also want to drill through at Service level.
I tried creating another join between the same two sources using the folowing columns
1. Portfolio
2. Cost Driver
4. Busines Area
5. Services
But Power BI wont allow me to create a join at Multiple levels within the same two sources.
- v-frfei-msft
Hi Anonymous ,
