jobf
Helper II
2 years agoMultiple differences between values in the same column
I need to calculate the difference between dates in the same column. For example: Field Input Date P1 Enzow 2024/01/24 P1 Plut 2024/02/25 P1 Plut 2024/02/19 P1 Plut 2024/02/...
- 2 years ago
hello jobf
please check if this accomodate your need.
Difference =
var _MinDate = MINX(FILTER('Table','Table'[Field]=EARLIER('Table'[Field])&&'Table'[Input]=EARLIER('Table'[Input])),'Table'[Date])
var _PreviousDate =
CALCULATE(
MAX('Table'[Date]),
ALL('Table'),
OFFSET(-1,ORDERBY('Table'[Date]),PARTITIONBY('Table'[Field],'Table'[Input]))
Return
IF(
'Table'[Date]=_MinDate,
BLANK(),
'Table'[Date]-_PreviousDate
)Hope this will help you.
