jobf's avatar
jobf
Helper II
2 years ago
Multiple differences between values ​​in the same column
I need to calculate the difference between dates in the same column. For example:
FieldInputDate
P1Enzow2024/01/24
P1Plut2024/02/25
P1Plut2024/02/19
P1Plut2024/02/10
P1Enzow2024/01/20
P2Plut2024/02/10
P2Enzow2024/01/20
P2Enzow2024/01/12
P2Enzow2024/01/10
I need to create a column that calculates the difference between the current date and the previous date in days, based on the Field and Input column. The final table would look something like this:
FieldInputDate Difference
P1Enzow2024/01/24 4
P1Plut2024/02/25 6
P1Plut2024/02/19 9
P1Plut2024/02/10
P1Enzow2024/01/20
P2Plut2024/02/10
P2Enzow2024/01/20 8
P2Enzow2024/01/12 2
P2Enzow2024/01/10
If there is no previous date, there should not be a value.
  • hello jobf
    please check if this accomodate your need.
    Difference =
    var _MinDate = MINX(FILTER('Table','Table'[Field]=EARLIER('Table'[Field])&&'Table'[Input]=EARLIER('Table'[Input])),'Table'[Date])
    var _PreviousDate =
    CALCULATE(
        MAX('Table'[Date]),
        ALL('Table'),
        OFFSET(-1,ORDERBY('Table'[Date]),PARTITIONBY('Table'[Field],'Table'[Input]))
    Return
    IF(
        'Table'[Date]=_MinDate,
        BLANK(),
        'Table'[Date]-_PreviousDate
    Hope this will help you.
  • hello jobf
    Difference =
    var _PreviousDate =
    CALCULATE(
        MAX('Table'[Date]),
        ALL('Table'),
    Return
    IF(
        BLANK(),
    • jobf's avatar
      jobf
      Helper II
      Is there a way to put a zero in place of this empty space in earliest dates?
      • Irwan's avatar
        Irwan
        hello jobf
        use 0 instead of BLANK for true value in if statement.
