Multi fact problem
- 9 years ago
In this scenario, what do you mean " 'Date d'analyse' is a date a few days before the 'Date de facture'." If this just a date to filter corresponding fact table, which means there's no direct relationship between 'Ventes' and 'Analyses', you should build date dimension into a common dimension.
" Power BI can't handle more than one filtering path"
You are correct. You can only keep one path between two tables based on relationship. So it's better to make "Single" cross filter direction between those common dimensions and fact tables.
- Jonathan_P9 years ago
Helper II
Thanks to both of you, v-sihou-msft and Greg_Deckler. Like you said, what I needed was a common date dimension between the 2 fact tables.
