Anonymous's avatar
5 years ago
MTD and MTD LY Random problem
Hi there everybody, I have a very odd problem. So ive got the following calculations using DATESMTD and then Dates MTD for the last period. I get perfect correct results for Current YEAR, however last year results seem to be getting correct and then suddenly it calculates up to 638, even tough it is 94 as you can see in the picture. As u can see im using a calendar table and Everytime I filter up to last day, which is yesterday, it comes up as 638 which is so randoom, any ideas?
  • Anonymous what is the definition for "2021 Faktas" measure?
    I can see here that last year(2020) it was 638 on the 2020-01-20 but why the hell would it go up until the 10th of January this year and then suddenly take that one value?
  • Anonymous is that the last transaction in Jan 2020? Make sense, if it is then make sense, coz you are using DATESMTD going back one year, so it will add everything for Jan 2020. It is not "why the hell", more about understanding how DAX works 😁
      parry2k  It is not the last transaction, I tried the same with the sameperiod last year, but it still gives me the same result.
      You can see in the picture below that it adds up correctly up to 94 on the 10th of January of this year and then suddenly its 638
    This is most of the transactions in 2020-01
  • Anonymous there is something else going on. Can you share a sample pbix file thru one drive/google drive. Remove any sensitive information before sharing
    I noticed that every time I use .Date at the end of the measure it does seem to work, however I then must use date hierarchy. Any ideas maybe??
  • Anonymous oh! I see .[date] means it has internal calendar table which is not recommended as a best practice.
    Two things:
    - mark your calendar table as date table (check my post here)
    - turn off auto date/time in options
    Check my latest blog post Year-2020, Pandemic, Power BI and Beyond to get a summary of my favourite Power BI feature releases in 2020
    I would ❤ Kudos if my solution helped. 👉 If you can spend time posting the question, you can also make efforts to give Kudos to whoever helped to solve your problem. It is a token of appreciation!
    ⚡Visit us at https://perytus.com, your one-stop-shop for Power BI-related projects/training/consultancy.⚡
