Ortignano
Helper II
1 year agoMeasure problem (problem with ALL)
Hi, I have a power by schema with three tables: ALLProducts(with MonthID_open, MonthID_MFG, Qtà fallita and a column model that is related to the FamilyTbl, a calendar table and Family tbl with a co...
- 1 year ago
Hi Ortignano ,
See the updated DAX:
VAR LastDateOpen = MAX('Calendar Lookup'[MonthID]) VAR Lastdate_shift_2_Month = LastDateOpen - 2 VAR FirstDate_Open = LastDateOpen - 11 VAR FirstDate_MFG = FirstDate_Open - 2 RETURN CALCULATE( SUM('AllProducts'[Qtà fallita]) + 0, FILTER( 'AllProducts', 'AllProducts'[MonthID_MFG] >= FirstDate_MFG && 'AllProducts'[MonthID_MFG] <= Lastdate_shift_2_Month && 'AllProducts'[MonthID_Open] >= FirstDate_Open && 'AllProducts'[MonthID_Open] <= LastDateOpen ), FILTER( FamilyTbl, FamilyTbl[Inverter Family] IN VALUES(FamilyTbl[Inverter Family]) ) )
Ortignano
Helper II
1 year agoThank you, it give me an error as : cannot convert value 'Family1' of type Text to type True/false
Bibiano_Geraldo
1 year agoHi Ortignano ,
CALCULATE(
FILTER(
'AllProducts',
FILTER(
FamilyTbl,
