Ortignano
Helper II
1 year agoMeasure problem (problem with ALL)
Hi, I have a power by schema with three tables: ALLProducts(with MonthID_open, MonthID_MFG, Qtà fallita and a column model that is related to the FamilyTbl, a calendar table and Family tbl with a co...
- 1 year ago
Hi Ortignano ,
See the updated DAX:
VAR LastDateOpen = MAX('Calendar Lookup'[MonthID]) VAR Lastdate_shift_2_Month = LastDateOpen - 2 VAR FirstDate_Open = LastDateOpen - 11 VAR FirstDate_MFG = FirstDate_Open - 2 RETURN CALCULATE( SUM('AllProducts'[Qtà fallita]) + 0, FILTER( 'AllProducts', 'AllProducts'[MonthID_MFG] >= FirstDate_MFG && 'AllProducts'[MonthID_MFG] <= Lastdate_shift_2_Month && 'AllProducts'[MonthID_Open] >= FirstDate_Open && 'AllProducts'[MonthID_Open] <= LastDateOpen ), FILTER( FamilyTbl, FamilyTbl[Inverter Family] IN VALUES(FamilyTbl[Inverter Family]) ) )
Bibiano_Geraldo
1 year agoHi Ortignano ,
The issue with your current formula is the use of ALLEXCEPT. While ALLEXCEPT excludes some filters (in your case, FamilyTbl[Inverter Family]), it removes all other filters, including those applied by slicers. This can cause the calculation to ignore slicer selections.
To fix this and ensure the measure respects the slicer for Inverter Family, you can use a slightly modified approach:
CALCULATE(
FILTER(
ALL('AllProducts'),
KEEPFILTERS(FamilyTbl[Inverter Family])
Ortignano
Helper II
1 year agoThank you, it give me an error as : cannot convert value 'Family1' of type Text to type True/false
- Bibiano_Geraldo1 year ago
Hi Ortignano ,
