Measure does not work with "string" values
- 2 years ago
Hi Anonymous ,
On https://www.phdata.io/blog/switching-metrics-in-power-bi/ I had found a blog that explained the setup of a switching metrics.
This was quite interesting and I tried…and it worked. From now I had – on the one hand – a nice slicer that allowed me to select between EUR currency, local currency and order quantity and -on the other hand – another visual that automatically changed from EUR to local currency or quantity. So far, so good!
Now it is my intention to adjust this switching approach.
The slicer that is based on a table that I had to create manually, should allow me to select specific options that our instruments can be built off.
Our instruments consists of a model code that can comprise of up to 32 different features and for each of these features you can select one option.
Let’s say the model code is VR1C9K7HD4100LTRXA131WA0…and I would like to know details about feature 10 (10th position of the model code).
From my slicer I would like to select e.g. “Option 10” and another visual (table or matrix) should list all available options as I had tried to explain with my original posting.
So the measure that I am looking for should return rather text than figures, as my sample data should show.
Sorry, if my explanation did confuse you…
Hi Orstenpowers ,
Try changing the sum part of the expression to:
Hope it helps!
Best regards,
Community Support Team_ Scott Chang
If this post helps then please consider Accept it as the solution to help the other members find it more quickly.
Hi Anonymous ,
Thanks for your valuable feedback!
I changed my measure accordingly, but unfortunately I get the following error message:
It states that type "Text" cannot be converted into type "Number".
Do you have any idea what else I could do?
Hi Orstenpowers ,
I can't think of any other way, can you make the columns number by power query?
Best regards,
Community Support Team_ Scott Chang- Orstenpowers2 years ago
Post Patron
Hi Anonymous ,
Thank you for your continued help!
In Power Query, I changed from type "Text" to "Integer", but then the values change to "Error"...😕- Anonymous2 years agoNot applicable
Hi Orstenpowers ,
Whether the column data has decimals, try to convert to Decimal number.
Best regards,
