macwhe's avatar
macwhe
5 years ago
max per order issue
Hi All,
I am struglling with MAX function. I have 2 dimension tables and on Facttable. between 2 dimensions there is a inactive relationship . and between the fact table and FreezeDate Snapshot there is one active relationship
First Dimension
Freeze date SnapShot
1-Sep-21
2-Sep-21
Second
Freeze Comparison Snaphot
31-Aug-21
1-Sep-21
facttable
FreezeDate0rderQuantity
1-Sep-21P100110
2-Sep-21P100120
1-Sep-21P10021
2-Sep-21P100210
The goals is to comapre the order qty bewteen those two dates. Lets suppose user selects as Freeze Date snapshot 1s SEP 2021 and Comaprison date is 31 AUG 2021. The results that I need to achieve should be like below . I need to display in visual TABLE.
Freeze date Comparison Snapshotorder Comparison SnapshotQuanity Comparison SnapshotFreeze Date SnapshotOrder Snaphot
QTY Snapshot
Qty Difference Between 2 freezes dates
31-Aug-21emptyEmpty1-Sep-21P100110-10
31-Aug-21EmptyEmpty1-Sep-21P100220-20
However the results that I have is : As you can see it shows the max order which is P1002 .
Freeze date Comparison Snapshotorder Comparison SnapshotQuanity Comparison SnapshotFreeze Date SnapshotOrder SnapshotQTY SnaphotQty Difference Between 2 freezes dates
31-Aug-21emptyEmpty1-Sep-21P100210-10
But if I drop the "order column "  from the fact table it shows correctly but I dont want to show the order column from Fact Table
Freeze date Comparison Snapshotorder Comparison SnapshotQuanity SnapshotFreeze Date SnapshotOrder QTYQty Difference Between 2 freezes dates"Order"
31-Aug-21emptyEmpty1-Sep-21P100110-10P1001
31-Aug-21EmptyEmpty1-Sep-21P100220-20P1002
these are my measures
Order Comaprison Snaphot=Calculate (
Max(Order).Facttable, Remove filters (FreezeDate Snapshot),
UserRelationship(freezedateSnapshot), (freezedateComparison Snapshot)
Qty Comparison =Calculate (
SUM(Qty).Facttable, Remove filters (FreezeDate Snapshot),
Order Snaphot=Max(Order).Facttable
QTY Snapshot=sum(Qty).facttable
  • Hi macwhe,
    Try measure as:
    Measure =
    IF(
        MAX(Facttable[FreezeDate])>=ALLSELECTED('Second Dimension'[Freeze Comparison Snaphot]) && MAX(Facttable[FreezeDate])<=ALLSELECTED('First Dimension'[Freeze date SnapShot]),
        1,
        0
    Here is the output:
    The demo is attached, please try it.
    If you still have some question, please don't hesitate to let me known.‌‌
    Link
    Is that the answer you're looking for? If this post helps, then please consider Accept it as the solution. Really appreciate!
  • Are these snapshot dates predefined or would it be easier to let the user select the date range via a slicer?
    • macwhe's avatar
      macwhe
      HI, the dates are selected by user  Below are the dates that I have available in the slicers. Basically  we have a new freeze date everyday depending on the business and at end of the month we also have a freeze. I forgot to mention I am using Direct Query. thanks a lot slicers
      • lbendlin's avatar
        lbendlin
        My question was if you could combine both slicers into one date range slicer.
  • v-xulin-mstf's avatar
    v-xulin-mstf
    Hi macwhe,
    Try measure as:
    Measure =
    IF(
        1,
        0
    Here is the output:
    Link
