Match data values from same column within a specific time period and cross validate it with another,
I have 3 Columns AccountNumber, TimePeriod, ProductName
Use Case: Match value in AccountNumber and ProductName within the same AccountNumber and ProductName column within TimePeriod between this year and pervious year. If both AccountNumber and ProductName in the same row matches with the same AccountNumber and ProductName in another row then the associated column should display as Legacy else New.
Sample Date
| AccountNum | TimePeriod | ProductName | Column Result |
| 12345 | 1-Nov-23 | Hike | Legacy |
| 12344 | 7-Mar-23 | Cycle | Legacy |
| 14567 | 5-May-24 | Car | Legacy |
| 17890 | 1-Dec-21 | Truck | Legacy |
| 12345 | 11-Jun-24 | Hike | Legacy |
| 18970 | 15-Nov-23 | Auto | Legacy |
| 17890 | 22-Apr-24 | Train | New |
| 12345 | 20-Jul-24 | Train | New |
I have tried many times in DAX but not able to get hte right combination.
Hi sviswanathan Can you try below calculated column replace table name with your model table
currently i have used legne
Column Result_R =
VAR CurrentYear = YEAR(TODAY())
VAR CurrentYearStart = DATE(CurrentYear, 1, 1)
VAR PreviousYearStart = DATE(CurrentYear - 1, 1, 1)
VAR CurrentYearEnd = DATE(CurrentYear, 12, 31)
VAR PreviousYearEnd = DATE(CurrentYear - 1, 12, 31)VAR IsCurrentOrPreviousYear =
'Legne'[TimePeriod] >= PreviousYearStart &&
'Legne'[TimePeriod] <= CurrentYearEndVAR IsLegacy =
CALCULATE(
COUNTROWS('Legne'),
FILTER(
'Legne',
'Legne'[AccountNum] = EARLIER('Legne'[AccountNum]) &&
'Legne'[ProductName] = EARLIER('Legne'[ProductName]) &&
'Legne'[TimePeriod] < CurrentYearStart &&
) > 0RETURN
IF(
IsCurrentOrPreviousYear &&
IsLegacy,
"Legacy",
"New"
)getting result:
Hope this helps
- rajendraongole1
Column Result_R =
CALCULATE(
COUNTROWS('Legne'),
FILTER(
'Legne',
) > 0RETURN
IF(
IsLegacy,
"Legacy",
"New"
)getting result:
Hope this helps
- sviswanathanRegular Visitor
Perfecto! Thanks worked like a charm. rajendraongole1
