8 years agoNot applicable
Keep spaces in column fields when using table/matrix
Hi, I'm struggling to create my own indentation in a table visualisation. I have a 'Description' Column with all my P&L Lines and an Indent column with numbers. I created a new column using Text...
- 8 years ago
Hi Anonymous,
Please turn off the "Word Wrap" option under Format pane.
Best regards,
Yuliana Gu
4 years agoNot applicable
Thank you for this simple solution to this problem. Saved me a lot of time.
