Joining tables with conditional statement using min and max
- 5 years ago
Hi, Anonymous
Please check the below picture and the link down below.
It is for creating a new column.
Goal Column CC =
VAR currentwell = Table1[Well]
MAX ( Table2[Category] ),
FILTER (
Table2,
Table2[Well] = currentwell
&& Table1[Number] >= Table2[Start Number]
&& Table1[Number] <= Table2[End Number]
)https://www.dropbox.com/s/fnj9itg4kd6z457/jklib.pbix?dl=0
Hi, My name is Jihwan Kim.
If this post helps, then please consider accept it as the solution to help other members find it faster, and give a big thumbs up.
Linkedin: linkedin.com/in/jihwankim1975/
Twitter: twitter.com/Jihwan_JHKIM
Hi, Anonymous
Goal Column CC =
FILTER (
Table2,
Really appreciate the quick and correct response. I didn't know that you can create columns that import data from other views without a live table-to-table relationship.
Thanks again!
