Issue with using Dual Mode
Hi Kolumam,
1) How does dual storage works and is it same as the direct query?
Dual tables have the same constraints as DirectQuery tables. These constraints include limited M transformations and restricted DAX functions in calculated columns. For more information, see Implications of using DirectQuery.
2) Based on my test, it refreshes according to the scheduled refresh.
Frank
- Kolumam8 years ago
Post Prodigy
If Dual storage uses schedule refresh, then I can use import for that. I am not asking for constraints, does it pull the data live?
Why the hell is this feature then used for?
- v-frfei-msft8 years ago
Hi Kolumam,
Dual tables can act as either cached or not cached, depending on the context of the query that's submitted to the Power BI dataset. In some cases, you fulfill queries from cached data. In other cases, you fulfill queries by executing an on-demand query to the data source.
For more details, please check the online document.
Frank
Hi Kolumam,
Does that make sense? If so, kindly mark my answer as a solution to close the case.
Frank
