Chelly
2 years agoFrequent Visitor
Issue with SELECTEDVALUE in Power BI - Need Help
Hello Power BI community,
I'm encountering an issue with the SELECTEDVALUE function when using a slicer for a specific year. If I choose the year 2020, for instance, the result only includes data for that year (e.g., 1000), but I actually want to retrieve the value for years less than 2020 (e.g., 10000).
Here's the snippet of my code:
_test = CALCULATETABLE(
DISTINCT(table[code]),
table[Statut] = 2,
table[year] < SELECTEDVALUE('YearTable'[Year], 2022),
table[Levels] = 2
Any insights or suggestions on how to achieve this would be greatly appreciated! Thanks in advance.
- lukiz84
Memorable Member
hi, try:
VAR SelectedYear = SELECTEDVALUE('YearTable'[Year], 2022) _test = CALCULATETABLE( DISTINCT(table[code]), table[Statut] = 2, table[year] < SelectedYear, table[Levels] = 2 )- ChellyFrequent Visitor
Appreciate your efforts, but the results remain unchanged.
- AnonymousNot applicable
Hi Chelly ,
You can refer to below steps:
result = VAR sel_ = SELECTEDVALUE ( YearTable[Year] ) RETURN IF ( MINX ( 'table', [year ] ) <= sel_, 1, 0 )Best Regards,
Adamk KongIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly
