Issue with merging data while using Power Bi for SEO
I'm using Power Bi for SEO, position analysis. Got two tables. First be like:
Keywords Position on 7/08/2017
A 10
B 11
C 12
The second one is:
Keywords Position on 07/09/2017
A 20
B 21
C 22
D 13
E 14
How can I merge them into one, which is like:
Keywords Position on 07/09/2017 Position on 7/08/2017
A 10 20
B 11 21
C 12 22
D -- 13
E -- 14
Sorry for the noob question.
Hi Kid_Koala,
Merge Table 2 with Table 1
Then Expand,
There is no duplication. I guess this is what you are looking for. Correct me if I'm wrong
- BeemsC
Resolver III
If you have a relationship between the 2 tables:
Just go to the query editor -> go to the table you want to add the column too -> On the top of ur screen select Add column -> Select custom column -> Insert the data you want to add -> Apply changes
If something is unclear let me know.
Good luck !- Kid_KoalaFrequent Visitor
Thanks for your message, BeemsC.
Unfortunately, that didn't help. There is a relations between those two tables, however, when I click 'custom column' I can only choose from the first table columns. When I try to do the same with the second one, I only can choose from the second table columns.
( sumit4732 )
Hi mate,
The problem with you approach is, when I do it like this, I've got two columns with keywords: from table 1 and from table 2.
It looks like:keywords table 1 Position table 1 keywords table 2 Position table 2
A 10 A 20B 11 B 21
C 12 C 22
D 13
E 14
I want to merge duplicates in keywords, but the best solution I found until now is to 'Merge tables' by keyword, so I get like:
Keywords position 1 position 2
A 10 null
A null 20
B 11 null
B null 21
C 12 null
C null 22
D null 13
E null 14
Then, I just click 'Delete Duplicates' on a column with Keywords, but it kills all the rows in position 2 with numbers, turning it into 'null'. I tryied to 'delete empty rows' in position 2 column, but it both didn't execute and seems like nonsense to me.
- CahabaData
Memorable Member
So it probably should be pointed out that a side-by-side merge of 2 days, just one time is fine. But if the data is coming in daily, then this approach cannot scale.
Instead the data should be appended into a single table in a normal structure:
Keywords Date Position
A 7/8/17 10
B 7/8/17 11
A 7/9/17 20
B 7/9/17 21etc
Then rely on Matrix visual or transform as part of the visual display and not as part of the table model.
Much thanks for your answer, CahabaData
Sure, I understand the scalability thing. Just needed that one for a one time report.
