2 years agoNot applicable
Issue with filtering through visuals when using custom column in field parameter
I'm having an issue where I have multiple bar charts, with the exact same field as x axis, and a field parameter as Y axis. Issue is when I click on a X-axis category to filter, I get an error. But...
littlemojopuppy
2 years agoAnonymous by chance did you create a table to support this visual? First...that's very bad form. But if you did, it sounds like there isn't a relationship between whatever is on the X axis and that table.
littlemojopuppy Thanks for the reply,
I used the create field parameters function or whatever you call it, which automatically makes a sort of table.
But like I mentioned filtering through slicers works, just not through the bar on a visual.
So I'm not enitrely sure that relationship is the issue?
When using the parameters without the extra column in the visual, filtering through clicking on bar chart works.
