medicina_khv1's avatar
medicina_khv1
1 year ago
Is it possible to create a mathematical algorithm using Power BI?
1. First row. Reference values ​​(min max)
2. Third row. Intermediate results.
3. Fifth row and below. Values ​​to 100. You can change 100 from 1 to 1000, for example: if you change it to 1, then all the values ​​in the columns of this row must be reduced by 100 times, if 100, then multiply by 10.
Problem statement: You need to find a row in the table in which the addition of the values ​​in the columns of this row with the corresponding values ​​of the columns in the intermediate results are in the reference range of the first line.
Neurologist.xlsx
If it is impossible to create such an algorithm using Power BI, then on which forum can I ask?
Best regards,
Evgeny
  • Where are the column names?  What does "intermediate"  mean in this context?  What is the desired algorithm?
  • v-sathmakuri's avatar
    v-sathmakuri
    Hi medicina_khv1 ,
    Thank you lbendlin  for the prompt response.
    Thank you!!
    v-sathmakuri
    Hi medicina_khv1 ,
    I wanted to check if you had the opportunity to review the information provided. Please feel free to contact us if you have any further questions. If the responses has addressed your query, please accept it as a solution and give a 'Kudos' so other members can easily find it.
    Thank you!!
    v-sathmakuri
    Hi medicina_khv1 ,
    I hope this information provided is helpful. Feel free to reach out if you have any further questions or would like to discuss this in more detail. If responses provided answers your question, please accept it as a solution so other community members with similar problems can find a solution faster.
    Thank you!!
