drmshahid
3 years agoNew Member
Integer array read as text by power BI, converting the type does not work
Reading data from a PostgreSQL database in power BI. One of the columns in my data is an integer array; so each cell has an array data. When Power BI reads it, it shows it as text. Furthermore, when ...
Ahmedx
3 years agoWhat do you want to do next with it?
= Text.Split(
Text.Select([posttimea rray],{"0".."9",","}),",") // so you get a list
List.Sum(
List.Transform(
Text.Split(
Text.Select([posttimea rray],{"0".."9",","}),","), Number.From)) // so you get the sum
