In need help with a measure for difference between two rows
For a report I need the accrual of vacation hours per year and per leave definition. This can be calculated by subtracting the column "leavehoursbalance" from the column "Totalentitlementhours" next year.
For example:
totalentitlementhours from leavedefinitionid 5006 in year 2025 = 202
leavehourbalanc from leavedefinitionid 5006 in year 2024 = 164
202 - 164 = 38
Measure I need = The acruall of leavedefinitionid 5006 in year 2025 is 38.
Thanks in advance
RobBeijers312 Try using this version
Accrual =
VAR CurrentYear = MAX('Table'[year])
VAR PreviousYear = CurrentYear - 1
VAR CurrentEntitlement =
CALCULATE(
SUM('Table'[totalentitlementhours]),
'Table'[year] = CurrentYear
VAR PreviousBalance =
CALCULATE(
SUM('Table'[leavehoursbalance]),
'Table'[year] = PreviousYear
IF(
ISBLANK(PreviousBalance),
BLANK(),
CurrentEntitlement - PreviousBalance
- bhanu_gautam
RobBeijers312 , Try using measure
DAX
Accrual =
CALCULATE(
CALCULATE(
CurrentEntitlement - PreviousBalance - RobBeijers312
Hi bhanu_gautam ,
Thanks for the reply.
Currently the outcome of the measure is the sum of totalentitlementhours. So it seems that the problem lies with the formula of the PreviousBalance. When I only return PreviousBalance the outcome is unfortunately blank.
- bhanu_gautam
Accrual =
CALCULATE(
CALCULATE(
IF(
BLANK(),
)- RobBeijers312
bhanu_gautam thanks, it works!
- RobBeijers312
Hi bhanu_gautam ,
The measure doesnt work at this moment. The current outcome is the oucome of CurrentEntitlement.
The fault at this moment is PreviousBalance. When I return PreviousBalance as the outcome the outcome is blank.
