How to write between function in power bi
- 8 years ago
Priya_K wrote:It worked when I use "&" instead of "and" in my formula in power query.
IF(
('Work Items - All history by month'[Inherent Risk Score]>17) &&
('Work Items - All history by month'[Inherent Risk Score]<25),
"critical",That is DAX. DAX uses a function similar to Excel - IF(condition, true, false) and as I noted above, you should use &&.
Power Query uses this - and it is case sensitive.
if condition then true else false
And if you have multiple conditions, then it is
if condition and condition and condition then true else false
If you are writing it as a calculated column in DAX, you want to use
=IF(
Table2[Tickets]>2 && Table2[Tickets]<4
,1
,0
You could use an AND() funciton in there, but AND() only allows two conditions, whereas you can use && until the cows come home.
If you are doing it in Power Query before it gets to DAX, (which I recommend for performance reasons), add a custom column then use:
if [Tickets] > 2 and [Tickets] < 5 then 1 else 0
Power Query can have multiple and statements. And or statements. And levels with parenthesis. Much more powerful.
Yes, I prefer Power Query. I am getting an error when I use and function in there.
- edhans8 years ago
Can you share that error, and maybe a screen shot of it?
- Priya_K8 years agoRegular Visitor
IF(
"critical",- edhans8 years ago
IF(
