Anonymous's avatar
6 years ago
How to replace empty cells to zero (0) in matrix column values using direct mode.
i am using direct query, 2 columns product service, product status and below is sample data
phase 1               open
phase 2               started
phase 3                waiting
phase 4                comlpleted
when i use this data into matrix i got below view, assume there are 30 open rows for phase 1,20 started rows for phase 2, 10 waiting rows for phase 3
and 05 completed rows for phase 4 then my matrix shows like below
product statusop    open, started, waiting , comlpleted
product service
phase1                   30
phase 2                                25
phase 3                                                 20
phase 4        05
in above matrix view i am getting empty values when there is no prodcuts compare with other phases, here i would like to show 0
when there is no prodcuts assigned or there is no data (null or blank)
in matrix rows are product service
columns are product status
values are count(product service)
my expected output like below
product status open started waiting comlpleted
product service
phase 1             30        0          0               0
phase 2              0        25         0                0
phase 3              0        0          10               0
phase 4              0        0            0             0
phase 4             0         0            0             05
i have tried with checking by isblank() like below
emptystatus= var test=calculate(count(table[product status])) return if(emptystatus= blank(),0,emptystatus)
and tried with diffrent options but still i am unable to show 0 where there is no data associated when the data is transorm into matrix.
Please look into this and provide your inputs. Thank you
Thank you
Mahi1827
    6 years ago
    Hi Anonymous ,
    I had a look at your file and have updated the file as you require.
    Download the file here
    Appreciate your kudo!! Mark this post as solution if this works for you.
    This can  e achieved by adding +0. A sample dax is below, create something like this
    Measure Value = CALCULATE([Measure]+0,'Table'[Column] in DISTINCT('Column'[Column]))
    Appreciate your kudos.
    Mark my post as solution if this helps.
      Hi NikhilKumar,
      Thank you for your response and time
      Actually i have tried with given logic but its look like still am getting blank instead of 0.
      here is my updated dax.
      statuscount=CALCULATE(count(table(productservice)+0,'Table'[product service] in DISTINCT('Table[[product service]))
      here is how the data look like for some example
      product status product service
      open                 phase1
      open                 phase1
      open                  phase1
      completed         phase 2
      completed          phase 2
      completed          phase 2
      completed          phase 2
      after adding data into matrix :
      Product status         open    completed
      product service
      phase1                      3
      phase2                                      4
      in above example i would like show 0 when there is no data associated with rows and columns
      my expected output like below:
      product service
      phase1                       3                      0
      phase2                       0                      4
      rows iam using as product service , columns using as Product status and values given as count(product service)
      here to avoid blanks i have used adding +0 in count(product service),tried with comparing length of the count and also tried with new logic suggested by you. but still iam not able to show 0 intstead of blank .
      please check and suggest your ideas. Thank you.
      Mahi 1827
        Hi Anonymous ,
        If possible can you share pbix removing sensitive data or a sampke pbix?
        Appreciate your kudos!!
