bastomi
3 years agoRegular Visitor
How to read power BI dataset to python Script
i want to read data from Power BI and insert to dataframe.. the data from SQL Server i'm following this code but still error : example code: error:
- 3 years ago
bastomi , Have you modified it manually? keep what power bi give you in term of the dataset as is
refer: How to create python visual: https://youtu.be/rX3-G8u5fwc
3 years agobastomi , Have you modified it manually? keep what power bi give you in term of the dataset as is
