How to read a .sas file in Power Bi using Python
Hi Guys,
I have a a sas file and I'm trying to open it in Power BI through python.
Can anyone helpme on this.
Anand
- amitchandak
AnandNamburi , refer if this can help
https://www.anegron.site/2018/11/27/read-sas-datasets-in-python/
- Icey
Hi AnandNamburi ,
Please check if this post could help you: How to Read SAS Files in Python with Pandas.
In addition, there are some posts introducing how to import SAS data into Power BI using R script, you can also try to use R.
Reference:
Importing SAS data into PowerBI;
Reading SAS (*.sas7bdat) Files In Power BI;
Reading SAS files from Power BI using R Script.
Best regards
Icey
If this post helps, then consider Accepting it as the solution to help other members find it faster.
- Icey
Hi AnandNamburi ,
Please let us know if the replies above are helpful.
If they are, please always accept the replies making sense as solution to your question so that people who may have the same question can get the solution directly.
If not, please give us more details.
Icey
