user35131's avatar
user35131
Helper III
4 years ago
How do i filter using a max variable within a variable chain while creating a table
i have a formula that looks like this. This works and gives me date above 01,01,2022
Final Table =
Var Table1=
"Pulled a table out of here
Var Table2 =
ADDCOLUMNS(Table1,"rank_order", RANKX(FILTER(Table1,[id]=EARLIER([id])),[date],,ASC,Dense))
var Table3 =
FILTER(Table2,[date] >= DATE(2022,01,01))
return Table3
However I want to do something like this becasue I want to create a dynamic table outcome.
Var Table1=
Var Table2 =
var Table3 =
FILTER(Table2,[date] >= DATE(MAX(Table2[date]),01,01))
return Table3
note before I had Date(2022,01,01), but I want Date(Max(table2[date]),01,01). However when I try to do it this way I get "Cannot identify the table that contains [date] column.
    4 years ago
    Hi user35131 ,
    I checked your code and I think Table2 should be a virtual table in your calculated table code. We couldn't use MAX to determind the column [Date] in virtual table directly. So you will get this error. You can try MAXX function to do this.
    Table =
    VAR _Table1 =
    "Pulled a table out of here"
    VAR _Table2 =
        ADDCOLUMNS (
            _Table1,
            "rank_order", RANKX ( FILTER ( _Table1, [id] = EARLIER ( [id] ) ), [date],, ASC, DENSE )
    VAR _Table3 =
        FILTER ( _Table2, [date] >= DATE ( YEAR ( MAXX ( _Table2, [Date] ) ), 01, 01 ) )
        _Table3
    My Sample:
    Result is as below.
    ā€ƒ
    Rico Zhou
  • user35131 , try table 3 like
    var Table3 =
    FILTER(Table2,[date] >= DATE(year(MAX(Table2[date])),01,01))
    return Table3
    • user35131's avatar
      user35131
      Helper III
      I got the same response that said cannot identify the table that contains [date] column.
        Hi user35131 ,
        Table =
        VAR _Table1 =
        VAR _Table2 =
            ADDCOLUMNS (
                _Table1,
        VAR _Table3 =
            _Table3
        My Sample:
        Result is as below.
        ā€ƒ
        Rico Zhou
