Rich_P
Helper II
8 years agoHelp with Simple Data Model
I'm trying to figure out the best way to compare record counts of data in one table against a forecast number in another table. I have tried my best to implement all the various scenarios found in th...
- 8 years ago
Ashish_Mathur
8 years agoRich_P
Helper II
8 years agoAshish - Thank you very much. This is quite a solution. Absolutely NO WAY I would have arrived at this on my own. I need to digest it to understand your approach. For anyone following this, here are the highlights from his solution.:
Ashish rewrote the measures as -
RR Goal Count:=if(
HASONEVALUE(Clients[Client]),
AVERAGE(qryCA_ManagementDashboard[RR Goal]),
SUMX(
SUMMARIZE(
VALUES(Clients[Client]),
[Client],"ABCD",
[ABCD])
RR Rcd Cnt :=
COUNTROWS ( qryCA_ManagementDashboard ),
qryCA_ManagementDashboard[Submittal Type] = "RR"
RR % Complete :=
DIVIDE ( [RR Rcd Cnt], [RR Goal Count] )
The relationships were defined as:
And the result looks like this:
- Ashish_Mathur8 years ago
You are welcome.
