Rich_P
Helper II
8 years agoHelp with Simple Data Model
I'm trying to figure out the best way to compare record counts of data in one table against a forecast number in another table. I have tried my best to implement all the various scenarios found in th...
- 8 years ago
Ashish_Mathur
8 years ago- Rich_P8 years ago
Helper II
Ashish - Thank you very much. This is quite a solution. Absolutely NO WAY I would have arrived at this on my own. I need to digest it to understand your approach. For anyone following this, here are the highlights from his solution.:
Ashish rewrote the measures as -
RR Goal Count:=if( HASONEVALUE(Clients[Client]), AVERAGE(qryCA_ManagementDashboard[RR Goal]), SUMX( SUMMARIZE( VALUES(Clients[Client]), [Client],"ABCD", AVERAGE(qryCA_ManagementDashboard[RR Goal]) ), [ABCD]) )
RR Rcd Cnt :=
COUNTROWS ( qryCA_ManagementDashboard ),
qryCA_ManagementDashboard[Submittal Type] = "RR"
RR % Complete :=
DIVIDE ( [RR Rcd Cnt], [RR Goal Count] )The relationships were defined as:
And the result looks like this:
- Ashish_Mathur8 years ago
You are welcome.
