Help with project
- 5 years ago
ephramz That's because you have some other measure that is returning a value so the row is going to get displayed. If you don't want that to happen you can basically take the same exact formula in a new measure that returns 1 or 0. So:
Selector = VAR __WhatToShow = SELECTEDVALUE('Table31a'[Column]) VAR __Value = MAX([Arising]) * MAX([Delta]) RETURN SWITCH(__WhatToShow, "positive",IF(__Value>0,1,0), "negative",IF(__Value<0,1,0), "zero",IF(__Value=0,1,0), 1 )You use the Filter pane to filter on this measure is 1. This is called a Complex Selector. The Complex Selector - Microsoft Power BI Community
I feel like I've solved 12 problems in one thread.
In my table visual, when i press the slicer, it shows me the "negative" values. but it doesnt remvoe the rows that arent negative Greg_Deckler
Selector =
1
