Help with project
- 5 years ago
ephramz That's because you have some other measure that is returning a value so the row is going to get displayed. If you don't want that to happen you can basically take the same exact formula in a new measure that returns 1 or 0. So:
Selector = VAR __WhatToShow = SELECTEDVALUE('Table31a'[Column]) VAR __Value = MAX([Arising]) * MAX([Delta]) RETURN SWITCH(__WhatToShow, "positive",IF(__Value>0,1,0), "negative",IF(__Value<0,1,0), "zero",IF(__Value=0,1,0), 1 )You use the Filter pane to filter on this measure is 1. This is called a Complex Selector. The Complex Selector - Microsoft Power BI Community
I feel like I've solved 12 problems in one thread.
Hi is there another way to do it, because my powerbi report keep says "not enough memory" is there another way to optimize this ?
ephramz Maybe:
Column =
VAR __Package = 'Table2'[Package]
VAR __Arising = RELATED('Table1'[Arising])
VAR __Delta = RELATED('Table1'[Delta])
IF(__Arising*__Delta <= 0,"Negative","Positive")- ephramz5 years ago
Helper II
Greg_Deckler
the two tables are related by strategy and package (which are column values)
Arising is a measure and delta is also a measure.
And the (Arising*Delta) is the name of the measure- Greg_Deckler5 years ago
ephramz So do you want an actual calculated column or do you want a measure that is a column in a table visual? Because measures and calculated columns do not tend to mix very well most of the time.
Helper II
Greg_Deckler
Okay, maybe let me explain myself again. Due to sensitivity of my data, i'll try to be as clear as possible, with some "sample" examples of the data.
I have two table and a seperate table (with all my measures)
Table 1: (Name: ENGG_VW_TRM)
Strategy Package and other columns
AA 1
AA 2
AC 3
Table 2: (Name: Repair Cap List)
AA 1
AA 2
AB 3
Both table are related according to the strategy and package column,
Table 3 Difference Impact (With all my measures)
"Arising" measure - Which is calculated based on table 1 "other columns values"
"Delta" measure Which is calculated based on table 1 "other columns values"
"Arising * Delta" measure the product of arising measure * delta measure
Based on the "Arising*Delta|" measure, it will generate a series of values which includes positive and negative values.
How do i create a column in Table 2 such that it will give me the corresponding "Arising*Delta" value because i need it to do a dynamic slicer for my report. Hopefully this makes things clear. Cheers
