Anonymous's avatar
6 years ago
help with power query builder
this might be really stupid query but i am struggling to get the desired output.
I am trying to join two tables. and would like the below output in the resultant table.
Table 1 (this table is result of joining two other tables)
IDAppCIdate close Incident
1SDWSDW india1/1/2020
3SDWSDW emea1/2/2020
3SDWSDW emea1/3/2020
2SDWsdw australia1/4/2020
2SDWsdw australia1/5/2020
table 2  (this table is result of joining two other tables)
IDAppCIProblem close
2SDWsdw australia1/6/2020
result needed after joining table 1 and 2 above, basically i need to get the date column from 2nd table if the number of rows do not match it should be fileed with nulls. currently due to left join we are getting duplicates. instead of 8 records i get somewhere around 20-30 odd records.
 Join
IDAppCIProblem closedate close Incident
1SDWSDW india1/1/20201/1/2020
3SDWSDW emea1/2/20201/2/2020
3SDWSDW emea1/3/20201/3/2020
2SDWsdw australia1/4/20201/4/2020
2SDWsdw australia1/5/20201/5/2020
2SDWsdw australia1/6/2020null
the CI column is what we have for common in the table.
      Thank you i will try the method in the link.
      And yes we do not have unique data in those two table. that is one of the issue. as mentioned table 1 and 2 are actually derived from 2 tables which had unique data.
  • v-yingjl's avatar
    v-yingjl
    Hi Anonymous ,
    Basically, need to create a dimension like an index column to delete the same rows in one of the tables. I have created an index column in table1 and use the below M code to filter rows, merge the new table1 with table2 to get the expected result:
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUQp2CYeQCpl5KZmJQLaRgZGBvqG+oVKsDlFKjFGUpOamIqkwooIKY7AKI7iK4pRyhcTS4pKixBxkx5gQp8xUKTYWAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [ID = _t, App = _t, CI = _t, #"close Incident" = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"ID", Int64.Type}, {"App", type text}, {"CI", type text}, {"close Incident", type date}}),
        #"Added Index" = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1),
        Custom1 = Table.SelectRows(#"Added Index",each
                        id=[ID],app=[App],ci=[CI],dc=[close Incident],
                        x =
                        Table.AddColumn(
                            #"Added Index","new",each
                            Table.RowCount(
                                        Table.SelectRows(
                                            #"Added Index",each
                                            [ID]=id and [App]=app and [CI]=ci and [close Incident]=dc
                [Index]=
                Table.Max(
                            Table.SelectRows(
                                x,each
                "Index")[ID]
                and
                Table.Max(
                            Table.SelectRows(
                                x,each
                "new")[new]>1
                or
                Table.Max(
                            Table.SelectRows(
                                x,each
                "new")[new]=1
        #"Removed Columns" = Table.RemoveColumns(Custom1,{"Index"})
        #"Removed Columns"
    Table1 will be like this:
    Merge table2 with it, expand columns and remove unnecessary columns, final result will be like this:
    The details about M code that you can refer the Applied steps in the right of power query.
    Sample file is attached that hopes to help you: help with power query builder.pbix
    Yingjie Li
    If this post helps then please consider Accept it as the solution to help the other members find it more quickly.
