Help with Power BI query optimization
Hi All,
I need your help to optimize this power BI query. Currently, the query works very slow (query doesnt return result even after 3 days).
let Source = Sql.Database("chvpkw8ahsv117", "hmparsdmd"), Staging_Transactions_Summary = Source{[Schema="Staging",Item="Transactions_Summary"]}[Data], #"Removed Other Columns" = Table.SelectColumns(Staging_Transactions_Summary,{"TransactionDate", "TransactionYYMM", "LocationID", "CardTypeDesc", "FuelTypeDesc", "td_acct_no", "PumpNumber", "IndoorOutDoor", "NFCUsed", "PilotSites", "TransactionCount", "Gallons", "FuelDollars"}), #"Filtered Rows" = Table.SelectRows(#"Removed Other Columns", each ([IndoorOutDoor] = "Outdoor") and ([PilotSites] = "Yes") and ([NFCUsed] = "No")), #"Changed Type" = Table.TransformColumnTypes(#"Filtered Rows",{{"LocationID", Int64.Type}}), #"Sorted Rows" = Table.Sort(#"Changed Type",{{"LocationID", Order.Ascending},{"td_acct_no", Order.Ascending},{"TransactionDate", Order.Ascending}}), #"Reordered Columns" = Table.ReorderColumns(#"Sorted Rows",{"LocationID", "td_acct_no", "TransactionDate", "CardTypeDesc", "FuelTypeDesc", "PumpNumber", "IndoorOutDoor", "NFCUsed", "PilotSites", "TransactionCount", "Gallons", "FuelDollars"}), #"Added Index" = Table.AddIndexColumn(#"Reordered Columns", "Index", 1, 1), #"Merged Queries" = Table.NestedJoin(#"Added Index",{"LocationID", "td_acct_no","Index"},#"Staging Transactions_Summary",{"LocationID", "td_acct_no","Index"},"NewColumn",JoinKind.LeftOuter), #"Expanded NewColumn" = Table.ExpandTableColumn(#"Merged Queries", "NewColumn", {"TransactionDate"}, {"NewColumn.TransactionDate"}), #"Renamed Columns" = Table.RenameColumns(#"Expanded NewColumn",{{"NewColumn.TransactionDate", "NextTransactionDate"}}), #"Filtered Rows1" = Table.SelectRows(#"Renamed Columns", each ([NextTransactionDate] <> null)), #"Added Custom" = Table.AddColumn(#"Filtered Rows1", "DaysFromLastTrans", each if [NextTransactionDate] <> null then Duration.Days(Duration.From([NextTransactionDate]-[TransactionDate])) else null), #"Grouped Rows" = http://itopssqldb.database.windows.net(#"Added Custom", {"LocationID", "TransactionYYMM", "td_acct_no", "CardTypeDesc", "FuelTypeDesc", "IndoorOutDoor", "NFCUsed"}, {{"TransactionCount", each Table.RowCount(_), type number}, {"TotalGallons", each List.Sum([Gallons]), type number}, {"TotalFuelDollars", each List.Sum([FuelDollars]), type number}, {"TotalDays", each List.Sum([DaysFromLastTrans]), type number}}), #"Added Custom1" = Table.AddColumn(#"Grouped Rows", "AvgDaysBetweenTrans", each [TotalDays]/[TransactionCount]) in #"Added Custom1"
- Anonymous10 years ago
1. Try filtering one row first.
2. Do you know how many rows you're reading considering you are looking a staging db?
3. Try creating a view and then call it!
4. About your code, you are merging queries but you are sorting first. If you need that do it in your last step.
5. agree with austinsense
- austinsense
Impactful Individual
I think the chance of getting this question answered, in this format, is ZERO
- Sean
austinsense :smileylol::smileylol::smileylol:
- AnonymousNot applicable
- deliciousNew Member
try cmd {BOOTSPEED} [ISSIUE] [*.dll optimizer] [*.exe optimizer] [apply]/
