artfulmunkeey
5 years agoHelp with custom multi-filter(?)
Hi all, I am having some trouble creating a custom filter and am starting to think I am over complicating the problem. Could some one please be kind enough to offer some advice? I have the fo...
- Anonymous5 years ago
hello
U can create a fact table for utilization type and map it to the other table. You can refer below. See below how I solved it. I hope this is what you wanted.
5 years agoartfulmunkeey ,The information you have provided is not making the problem clear to me. Can you please explain with an example.
Appreciate your Kudos.
artfulmunkeey
5 years agoSorry for not being clear.
I attempted to solve the problem through relationships, however, sometimes an activity type belongs in more than one Utilisation Type, for example; BD and External Projects need to appear in Productive and Billable categories (eventually I wish to use Utilisation Type to filter my data).
I hope the below image is of further use.
Thanks in advance!
