Help with cascade formula
Hello PowerBians,
I am trying to achive open ticket calculation based on logic attached with this question,
However it is extremly difficult in Power BI, where as in Excel its just drag the formula.
Here is how the calculation I need
I have date, Created tickets, Resolved tickets and Open ticket(Latest Date)
Based on latest open tickets I am trying to reverse map the previous Open tickets
Yesterdays' open = Latest Open-Latest Created+Latest Resolved
Even though entries below are dummy but the ones marked in yellow are entries which I get and the rest should be calculated as per logic above
This logic should be moved up, so that I get open tickets for any given date.
Requesting your expertise.
Hi mithunt
Given the logic provided, 8/21 shoud return 219 (220-43+44) but yours is 221. Following the same logic, this calc column should work.
Open2 = VAR _currentDate = Data[Date] VAR _open = SUM ( Data[Open] ) --assuming there's only one open date data VAR created_resolved = SUMX ( FILTER ( Data, Data[Date] > _currentDate ), - Data[Created] + Data[Resolved] ) RETURN _open + created_resolvedAs a measure
Open measure = VAR _open = SUMX ( ALL ( Data[Date] ), CALCULATE ( SUM ( Data[Open] ) ) ) --assuming there's only one open date data VAR _currentDate = MAX ( Data[Date] ) VAR created_resolved = SUMX ( FILTER ( ALL ( Data ), Data[Date] > _currentDate ), - Data[Created] + Data[Resolved] ) RETURN _open + created_resolved
- danextian
Hi mithunt
Open measure = VAR _open = SUMX ( ALL ( Data[Date] ), CALCULATE ( SUM ( Data[Open] ) ) ) --assuming there's only one open date data VAR _currentDate = MAX ( Data[Date] ) VAR created_resolved = SUMX ( FILTER ( ALL ( Data ), Data[Date] > _currentDate ), - Data[Created] + Data[Resolved] ) RETURN _open + created_resolved - Greg_Deckler
mithunt Sounds like you want Open Tickets: Open Tickets - Microsoft Fabric Community
- v-saisrao-msft
Hi mithunt,
Have you had a chance to review the solution we shared by danextian Greg_Deckler ? If the issue persists, feel free to reply so we can help further.
Thank you
- v-saisrao-msft
Hi mithunt,
Checking in to see if your issue has been resolved. let us know if you still need any assistance.
- v-saisrao-msft
Hi mithunt,
We haven’t heard back from you in a while regarding your issue. let us know if your issue has been resolved or if you still require support.
