Help with ARR evolution using Waterfall visualization in Power BI
Hello Team,
I'm facing an issue when trying to visualize the evolution of my ARR in Power BI.
I want to display the evolution of my ARR according to the variations by Reason type (New Account, Upsell, Downsell, Churn).
When I use the Waterfall visualization, I only get the variations, but I’m missing the starting values before variation (BoP) and the final values after variation for each quartile (EoP).
What I would like to achieve is a visualization similar to this design for Q1:
I tried to do it following this tutorial
https://businessintelligist.com/2020/06/12/power-bi-dax-how-to-make-waterfall-charts-work-showing-starting-and-ending-values/
But i have a Quarter filter that can change with the time so when you try to do it, it doesn't work
Is it possible to create this type of visualization in Power BI? If yes, how can I proceed?
I am attaching the Power BI file as well.
Thank you in advance for your help!
Hi community, I found this article and simply reproduced the same procedure, which allowed me to achieve the desired result.
Thanks v-karpurapud for your help.
- Chateauunoirr
Advocate I
So, I wasn't able to attach the Power BI, but I just uploaded it via an external link.
If I don't know how to do it, just let me know.
https://limewire.com/d/bTrsA#B7PttScxLG- v-karpurapud
Hi Chateauunoirr
Welcome to the Microsoft Fabric Forum.
I have made the necessary changes to the PBIX file based on your request regarding the ARR evolution using the Waterfall visualization. The updated file now includes the BoP and EoP values, along with the variations by reason (New Account, Upsell, Downsell, Churn) across the selected quarter. I’ve included relevant screenshot for your reference.Please take a moment to review them and see if this solution aligns with your requirements.
If not, kindly share any additional details or clarification so we can make the necessary adjustments.We’re happy to assist you further and ensure the solution fully meets your requirements.
Best regards,
Karpurapu D
Microsoft Fabric Community Support!- Chateauunoirr
Advocate I
Hi v-karpurapud
Thank you very much for your reply!
The only problem I see is the amount of the BoP, which is 4,718,000, which then distorts the EoP.
I'll take the time to look at your logic because what you've implemented will help me. I'll come back to this forum to keep you updated and, perhaps, submit the PBI solution.Sincerely,
- v-karpurapud
- v-karpurapud
Hi Chateauunoirr
Thank you. - v-karpurapud
Hi Chateauunoirr
Thank you.- Chateauunoirr
Advocate I
