Anonymous's avatar
8 years ago
Help required - Power bi scenario
HI All,
I'm new to Power bi .....trying to design a measure as below
we have fact table Appointments which consists of
Apointment IDAppointment start date Client NOTypeStatusFew othe rfields
123410/10/2018100ScreenComplete
123516/10/2018101screen Complete
123611/10/2018100testopen
123717/10/2018102screenCancelled
Another table Which gives the result of appointment
Client NOresult
1011
1020
I'm trying to find out
Appointment type screen with status completed and who have result as one --- which is easy
in the second step I need to find wether this client has a test apointment  in same table Appointment and this test appointment should be after screen apointemnt i.e test appointemnt start date > screen appointment date.
Many thanks in advance for your suggestions.
  • v-lili6-msft's avatar
    v-lili6-msft
    hi, Anonymous
    After my test, You could use this formula as below
    Measure = var _table=CALCULATETABLE(SUMMARIZE(Table1,Table1[Client NO],"days", DATEDIFF(CALCULATE(MAX(Table1[Appointment start date ]),Table1[Type]="screen"),CALCULATE(MAX(Table1[Appointment start date ]),Table1[Type]="test"),DAY))) return
    var _count= CALCULATE(COUNTAX(FILTER(_table,ISBLANK([days])=FALSE()),Table1[Client NO])) return
    IF(ISBLANK(_count),0,_count)
    Result:
    here is pbix, please try it.
    https://www.dropbox.com/s/5hbnsdkvan3scad/Help%20required%20-%20Power%20bi%20scenario.pbix?dl=0
    Lin
      Many Thanks for the solution v-lili6-msft. I was just struggling hard trying many ways as I'm new to Powerbi/DAX.
      I still have the issue  when I filter with start date it picks up all the test appointments with in start date .
      I dont want to apply filter on test Appointment date .i.e
      IF I filter for a month .. I pick up all screens completed with result = 1 in the month and any subseqent test apointments which can be anytime in future i.e after screen date.
      Hope I dnt confused you much.
      Thanks again for this.
