Help regarding Parameters for changing Data Sources
hi, Anonymous
You may try to use Parameters in Power BI.
and here are some blogs for you to refer to:
https://www.mssqltips.com/sqlservertip/4475/using-parameters-in-power-bi/
https://powerbi.microsoft.com/en-us/blog/deep-dive-into-query-parameters-and-power-bi-templates/
hope these can help you.
Lin
Hi v-lili6-msft
Thanks for sharing the documents, actually I went through them before posting my question. All those documents has steps to pass parameters when source is SQL Server database. It is straight forward when the source is SQL Server as it has option to select parameter as source. But my source is Impala and it uses ODBC connectivity. Due to this I am finding difficult to pass the parameter while changing to different sources. Please let me know if I am not clear.
