7 years agoNot applicable
Help regarding Parameters for changing Data Sources
Hello, I have created report which is connected to dev environment but now I want to point the report to test environment. Both dev and test are present on same server but in different schemas. How ...
LivioLanzo
Solution Sage
7 years agoHi Anonymous - did you update the M code and link it to the parameter ?
Hi LivioLanzo
No I havent. I am bit confused how to edit the M code and to link the parameter. Below is the M code for the table:
Source = Odbc.DataSource("dsn=Dev", [HierarchicalNavigation=true]),
IMPALA_Database = Source{[Name="IMPALA",Kind="Database"]}[Data],
emp_Schema = IMPALA_Database{[Name="emp",Kind="Schema"]}[Data],
employee_Table = emp_Schema{[Name="employee",Kind="Table"]}[Data]
employee_Table
