Help need with long DAX code
- 1 year ago
Hi ArchStanton - Absolutely! inline comments you can reuse it eg: // . This measure calculates the number of days a case spent
Days in Adj =
IF (
// Check if any of the adjudication-related date fields are not blank
NOT ( ISBLANK ( 'Cases'[datepassedtoadjudication] ) )
|| NOT ( ISBLANK ( 'Cases'[dateassignedforadjudication] ) )
|| NOT ( ISBLANK ( 'Cases'[dateacceptedforinvestigation] ) ),// If the case has not been resolved yet (no resolution date), calculate days until today
IF (
ISBLANK ( 'Cases'[Resolution Date] ),
DATEDIFF (
// Determine the earliest adjudication date to start counting from
IF (
ISBLANK ( 'Cases'[datepassedtoadjudication] ),
IF (
ISBLANK ( 'Cases'[dateassignedforadjudication] ),
// Fallback if both other dates are blank
'Cases'[dateacceptedforinvestigation],
// Use dateassignedforadjudication if available
// Prefer datepassedtoadjudication if available
NOW (), // Use current date if no resolution
DAY
),// If the case has been resolved, calculate days until resolution date
DATEDIFF (
IF (
IF (
'Cases'[Resolution Date],
DAY
),// If no relevant adjudication dates exist, return blank
BLANK ()
)HOpe this helps.
Thanks for this, I didn't realise things could be simplified so much using COALESCE, could you please kindly add comments to it so I can get my head around it?
Days in Adj =
VAR StartDateToUse =
// Choose the first of these dates which has a non-blank value
COALESCE (
'Cases'[datepassedtoadjudication],
'Cases'[dateassignedforadjudication],
VAR EndDateToUse =
// If resolution is non-blank then use that, otherwise use today
COALESCE (
TODAY ()
VAR Result =
IF (
NOT ISBLANK ( StartDateToUse ),
// Only return a result if there is a valid starting date
DATEDIFF (
StartDateToUse,
EndDateToUse,
DAY
Result
I hope this clears it up
- ArchStanton1 year ago
Power Participant
Thanks, much appreciated! 👍
