meikastler
3 years agoFrequent Visitor
Help! Month Ordering Problem
First and foremost, thank you SO MUCH to whoever can help me! I have a presentation on this within the next few hours and I can't seem to get the months for a matrix to line up properly. I looked up ...
- 3 years ago
Hi - Can you ensure that, under the Table View of the table with the dates, you've chosen to sort the "Month" column by the "Month Order" column?
If not, to do this from the Table view:
- highlight/select the Month column
- choose the "sort by column" from the "column tools" menu
- choose to sort by Month Order
Screenshot below where I've got slightly different column names to you, but same principle applies
Good luck!
Matt
m13eam
Resolver III
3 years agoHi - Can you ensure that, under the Table View of the table with the dates, you've chosen to sort the "Month" column by the "Month Order" column?
Good luck!
Matt
