2 years agoNot applicable
Help me plz, Problem in Visualization on Matrix
Hi, Everyone
I want to add Field Material, MaterialShortText, and ValuationType. But the problem with the After picture is that I don't want the total amount. I want the result in the Before picture, Please tell me how to format your visual.
Thankyou.
Before
After
If you don't need any subtotals, Go to Format Visual > Row Subtotals > and turn Off the whole thing.
if you still need some sub-totals, turn on Per row Level and then select the Row Level > Rows and turn off Show subtotal
- vicky_
- AnonymousNot applicable
I can do it now. Thank you for your help.
