JothiG
Helper III
1 year agoHelp help - Dax correction
Hi, I have requirement area chart as like shown in above. area area should show the value of last month value break up in series label . for example (2025 should show the August month value ...
- 1 year ago
Hi JothiG,
Thank you FarhanJeelani, for your insights.
I reproduced your issue with sample data and was able to create the issue in Power BI. I made the chart and verified the results. I've attached the PBIX file for your reference.
Last Month Value = VAR _yr = MAX('yarn data'[Stock_finyear]) VAR _max_month = CALCULATE ( MAX ( 'yarn data'[month_sorter] ), FILTER ( ALL ( 'yarn data' ), 'yarn data'[Stock_finyear] = _yr ) ) RETURN CALCULATE ( SUM ( 'yarn data'[Value] ), 'yarn data'[Stock_finyear] = _yr, 'yarn data'[month_sorter] = _max_month )Thank you.
v-saisrao-msft
1 year agoHi JothiG,
Have you had a chance to review the solution we shared earlier? If the issue persists, feel free to reply so we can help further.
