JothiG's avatar
JothiG
1 year ago
Help help - Dax correction
 I have requirement area chart as like shown in above. area area should show the value of last month value break up in series label . for example (2025 should show the August month value but not all month sum).
below dax not working
var _yr = max('yarn data'[Stock_finyear])
var _max_month = CALCULATE(
MAXX(
    FILTER(ALL('yarn data'),'yarn data'[Stock_finyear]=_yr),
    'yarn data'[month_sorter]
var sum_val = CALCULATE(
SUM('yarn data'[value])
    'yarn data'[value]
sum_val
  • Hi JothiG,
    Thank you FarhanJeelani, for your insights.
    I reproduced your issue with sample data and was able to create the issue in Power BI. I made the chart and verified the results. I've attached the PBIX file for your reference.
    Last Month Value =
    VAR _yr = MAX('yarn data'[Stock_finyear])
    VAR _max_month =
            MAX ( 'yarn data'[month_sorter] ),
            FILTER ( ALL ( 'yarn data' ), 'yarn data'[Stock_finyear] = _yr )
        SUM ( 'yarn data'[Value] ),
        'yarn data'[Stock_finyear] = _yr,
        'yarn data'[month_sorter] = _max_month
  • Hi JothiG ,
    The issue is that sum_val is summing all months in the year (and you even have an invalid filter expression 'yarn data'[value]).
    You need to filter the sum to only the last month of that year.
    You can try the approach that returns the value for the last month of the current year context (and works well when the visual shows Year on the axis).
    Using SELECTEDVALUE (works well when Year is in the visual axis)
    Last Month Value = VAR _yr = SELECTEDVALUE('yarn data'[Stock_finyear]) VAR _lastMonth = CALCULATE( MAX('yarn data'[month_sorter]), ALL('yarn data'), 'yarn data'[Stock_finyear] = _yr ) RETURN IF( NOT ISBLANK(_yr), CALCULATE( SUM('yarn data'[value]), ALL('yarn data'), 'yarn data'[Stock_finyear] = _yr, 'yarn data'[month_sorter] = lastMonth ), BLANK() )
     or,
    If you prefer MAX context (works similarly when there’s a single year in context)
    Last Month Value = VAR _yr = MAX('yarn data'[Stock_finyear]) VAR _lastMonth = CALCULATE( MAX('yarn data'[month_sorter]), ALL('yarn data'), 'yarn data'[Stock_finyear] = _yr ) RETURN CALCULATE( SUM('yarn data'[value]), ALL('yarn data'), 'yarn data'[Stock_finyear] = _yr, 'yarn data'[month_sorter] = _lastMonth )
    Please mark this post as solution if it helps you. Appreciate Kudos.
    • JothiG's avatar
      JothiG
      it is also not working ...
  • v-saisrao-msft's avatar
    v-saisrao-msft
    Hi JothiG,
    Last Month Value =
    VAR _max_month =
    v-saisrao-msft
    Hi JothiG,
    Have you had a chance to review the solution we shared earlier? If the issue persists, feel free to reply so we can help further.
    v-saisrao-msft
    Hi JothiG,
    Checking in to see if your issue has been resolved. let us know if you still need any assistance.
    • JothiG's avatar
      JothiG
      yeah. it's working now.
        v-saisrao-msft
        Hi JothiG,
        Thank you for the update. Could you please share the steps you took to resolve the issue? This information would be helpful for other community members.
