DiePic's avatar
DiePic
Icon for Resolver II rankResolver II
3 years ago
Help for power query M code FILTER
Hi all,
here below I've a sql query that works fine.
I need to add a filter on column [Transaction Date].
the filter should be the equivalent of sql "WHERE YEAR([Transaction Date]) = '2023' AND MONTH([Transaction Date])='03' ".
Then I'll try to pass data 2023 and 03 as dinamic paramaters if possible.
Thanx in advance for any help or suggestion.
(continuously of https://community.powerbi.com/t5/Desktop/Retrive-data-from-visual-object-to-use-as-parameters-in-query/m-p/3107901#M1053352 where the filter is for more selections and I dont find a way to filter only year and month of date)
    3 years ago
    Hi DiePic ,
    Please have a try.
    Add a custom column.
    e.g. = Table.SelectRows(#"Changed Type", Date.Year([date])=2023 and Date.Month([date])=3
    If it does not help, please provide more details with your desired output and pbix file without privacy information (or some sample data) .
    Community Support Team _ Rongtie
1 Reply
    Hi DiePic ,
    Please have a try.
