baaaailey's avatar
baaaailey
3 years ago
Help converting DAX column into Power Query
Hi All - I created some DAX custom columns to later use reference tables for a bridge, without realizing that they could not be used in Power Query. I am not as familiar with PQ yet as I am with DAX syntax, and could use some help with transferring them over to power query formulas. I have 2 tables with 3 DAX columns within each table that I used to clean-up some of the data and format.
Here is the first table's DAX Columns:
Table 1: vw_Fact_SalesOrderLine
DAX 1: TrimmedSalesOrderId = TRIM(vw_Fact_SalesOrderLine[Sales order ID])
DAX 2:
SalesOrderId = IF(LEFT(vw_Fact_SalesOrderLine[TrimmedSalesOrderId],5)="1900-",REPLACE(vw_Fact_SalesOrderLine[TrimmedSalesOrderId],1,5,""),IF(LEFT(vw_Fact_SalesOrderLine[TrimmedSalesOrderId],3)<>"SO0","SO0"&vw_Fact_SalesOrderLine[TrimmedSalesOrderId],vw_Fact_SalesOrderLine[TrimmedSalesOrderId]))
DAX 3:
SalesOrderLineKey = vw_Fact_SalesOrderLine[SalesOrderId]&"-"&vw_Fact_SalesOrderLine[Item ID]
Table 2: Complaints
DAX 1:
CleanSalesOrderId = IF(LEFT(Complaints[SO__c],2)="00",REPLACE(Complaints[SO__c],1,2,"SO0"),IF(LEFT(Complaints[SO__c],4)="SO00",REPLACE(Complaints[SO__c],1,4,"SO0"),IF(LEFT(Complaints[SO__c],3)<>"SO0","SO0"&Complaints[SO__c],Complaints[SO__c])))
DAX 2:
SalesOrderIdKey = if(left(Complaints[CleanSalesOrderId],4)="SO00",REPLACE(Complaints[CleanSalesOrderId],1,4,"SO0"),if(left(Complaints[CleanSalesOrderId],6)="SO0SO0",REPLACE(Complaints[CleanSalesOrderId],1,6,"SO0"),Complaints[CleanSalesOrderId]))
DAX 3:
SalesOrderItemKey = IF(Complaints[Product_Name__c]="MULTIPLE", Complaints[SalesOrderIdKey],if(Complaints[Product_Name__c]<>"",Complaints[SalesOrderIdKey]&"-"&Complaints[Product_Name__c],Complaints[SalesOrderIdKey]))
Please let me know if you need any other information that I'm missing to help me with this, Much Appreciated!
  • Hi, baaaailey ;
    DAX 1: add custom column
    =Text.Combine(List.Select(Text.Split([Sales order ID]," "), each _<>"")," ")
    DAX 2:
    =if Text.Middle([TrimmedSalesOrderId],0,5) ="1900-" then Text.AfterDelimiter([TrimmedSalesOrderId], "1900-")
    else if Text.Middle([TrimmedSalesOrderId],0,3) ="SO0"
    then [TrimmedSalesOrderId]
    else "SO0"&[TrimmedSalesOrderId]
    DAX 3:
    =[SalesOrderId]&"-"&[Item ID]
    Table 2: Complaints
    DAX 1:
    if Text.Middle([SO__c],0,2) ="00" then
        "SO0"& Text.Middle([SO__c],2,99999)
    else if  Text.Middle([SO__c],0,4) ="SO00" then
          "SO0"& Text.Middle([SO__c],4,99999)
    else if Text.Middle([SO__c],0,3) <>"SO0" then
          "SO0"& [SO__c]
          else [SO__c]
    Community Support Team _ Yalan Wu
  • v-yalanwu-msft's avatar
    v-yalanwu-msft
    Hi, baaaailey ;
    DAX 2:
    DAX 3:
    Table 2: Complaints
    DAX 1:
          "SO0"& [SO__c]
          else [SO__c]
    • baaaailey's avatar
      baaaailey
      Thank you very much! With your help in the previous conversions from DAX to power query, I tried to do the last 2 DAX columns from the Complaints table, but am getting an error.
      if
       Text.Middle([CleanSalesOrderId],0,4) ="SO00"
        then
         "SO0"& Text.Middle([CleanSalesOrderId],4,"SO00")
      else
        if
         Text.Middle([CleanSalesOrderId],0,6) ="SO0SO0"
          then
           "SO0"& Text.Middle([CleanSalesOrderId],6,"SO0SO0")
             else
       [CleanSalesOrderId]
      Expression.Error: We cannot convert the value "SO00" to type Number.
      Details:
      Value=SO00
      Type=[Type]
      Can you see why I am getting this error? The column is of type Text.
